07-07-2009 01:54 PM
07-07-2009 02:33 PM
Could you provide some actual values for sample rate and number of samples instead of those silly globals? Also, you have nothing to configure the digital timing.
I also don't understand your comment about not being able to find an example. There's one called Multi-Function-Synch AI-Read Dig Chan. It's under Hardware Input and Output>DAQmx>Synchronization>Multi-Function. Try that.
07-07-2009 04:32 PM
07-07-2009 04:52 PM
Sorry, I did not look at the spec details until now. I assumed it was a regular M series device but it's a USB one and I don't see a way to do hardware timed digital input. Since that is the case, you would get a single digital sample for each of the multiple samples with the analog read. So, going back to your original VI, all of my assumptions were incorrect. I'll to prlay around with it some more.
