How do I play a 6-channel wave file to a specific audio device?
I have tried the Labview standard audio functions, that all returns an error. 2-channel wave file is no problem.
(1,974 Views)
Post your code as start. And your code is NOT a picture. The Labview sound card VIs should support as many outputs as you have channels on your sound card. But it may also be problems the sound file format it self. See if you can create (write) a 6 ch sound file in Labview. If you can do this you should be able to open the latter file
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(1,966 Views)
