04-26-2006 12:41 AM
04-26-2006 01:01 AM - edited 04-26-2006 01:01 AM
Hi Kindred,
Search this site for VISA, "serial port", and "parallel port".
I think the signals on a PCs serial port (if it has one) are 0 or 10V (+/-?), and the parallel port signals are around 0/3.8V. My memory is terrible, so your results may vary, but there is a significant difference. Anyway, its trivial to set them - once you've done your homework.
Maybe this will get you started!
Cheers.
Message Edited by Dynamik on 04-26-2006 01:01 AM
04-26-2006 07:47 AM - edited 04-26-2006 07:47 AM
Message Edited by Ed Dickens on 04-26-2006 07:48 AM
04-18-2013 04:09 PM
Could you please help me out? I am trying to use this Labview to power a LED on my NI ELVIS. Attached is my LABVIEW. I cannot get the ELVIS to power the LED no matter what I do. Basically I have a seires of TF booleans that I feed into a digital output in the hopes that each will power a different LED.
04-18-2013 04:45 PM
Did you select a channel? I know nothing about the ELVIS boards but I believe they should mimic a standard DAQmx device. You have to tell the DAQ Assistant where to send the signal somehow. Click Add Channel (the + sign) and pick a physical output if you haven't already done so.
