09-19-2014 03:50 PM
I am trying to set up a systerm that requires multiple temperature measurements. I am able to make one RTD measure. But if I mirror the same code to create two measurements, i am getting an Error - 50103 "the specified resource is reserved". I have just begun using LabVIEW, so any and all help is valuable. If there is already material available on this topic, would you direct me there please.
09-19-2014 04:16 PM
09-19-2014 07:44 PM
You can have as many channels of the same type (in this case Analog Input) in a task. So your simple solution would be to have four channels in your task. You will also need to set your DAQmx Read to be for Multiple Channels.
09-22-2014 09:23 AM
Yup read Multi-channel Single Sample with a single task.
That being said this won't be "simultaneous". That implies at the same instant in time all 4 will be read. This just won't be true without a simultaneous sampling card. Without that card your readings will likely be fraction of a milliseconds appart and for temperature that should be more than enough. How much can temperature change in 0.001 seconds? But for other signal types like trying to read a phase off set in a sine wave you will need a true simultaneous sampling card.
Get going with G! - LabVIEW Wiki.
14 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
