Hi Pitata,
To find the second menu you want, right click on the Front Panel Icon (top right of the front panel) and select "Show Connector".
This will give you the connector pane (how you get data into and out of Sub-VIs).
Once you have the connector pane in place of the icon on the front panel. You want to right click the connector pane and select "Patterns" this takes you to the first menu you wanted.
Beaten to the punch with a much better link.
Hope this helps you.
Regards
JamesC
NIUK and IrelandMessage Edited by JamesC on 08-09-2006 12:40 PM
