How do I make the particular column to editable one in the multicolumn list box?
I am updating different parameters in the multicolumn list box.I am having four columns.
I want to make 3 columns non editable to user and 4th column is editable one.
How do i do this?
Help me
Regards
Meenatchi
(3,308 Views)
Select a "flat box" from decorations->Flat box, resize/move it to exactly cover the 3 columns and paint it transparent .
-Kumar.B
(3,301 Views)
Hi
You could also use the eventstructure to check the modified column.
Have a look at the attached vi.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,286 Views)
Your question title & the message you ve posted are contradictory to each other. Smiley Happy
Normally a Multicolumn Listbox is a non-editable one, in that while you run you wont get the labeling tool to type some text.
I think you can instead use a Table to achieve your purpose. Also see the below link.
http://forums.ni.com/ni/board/message?board.id=170&message.id=131631#M131631
Or, the attached VI, modified from that post, of course. Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
(3,284 Views)
