From 11:00 PM CDT Friday, Nov 8 - 2:30 PM CDT Saturday, Nov 9, ni.com will undergo system upgrades that may result in temporary service interruption.
How do I make one listbox's choices be dependent on another listbox selection?
I want one listbox that allows user to choose 1 of 3 units. Depending on which unit is selected, a 2nd listbox will display/provide user inputs for tests that are valid for that type unit selected. I am totally new to Labview and am struggling greatly. Any help appreciated!
(2,731 Views)
Paul,
wire the numerical value of the first listbox to a case statement. Inside the case you can build an array of strings that correspond to the values you want to display in the 2nd list box. then create a property node for the 2nd list box and select the 'item names' property - this is an array of strings which will be the names that appear in the listbox. wire the array from the listbox to this property. hope this helps.
pat
(2,731 Views)
Having some trouble here... I did per your suggestion the build array and the case statement. However, when I try to wire the output of the case into the ItemNames property box, Labview will not show a complete connection--but rather broken wires. How do I get the ItemNames to accept the array output? Thanks, Paul
(2,731 Views)
It'll work a lot better if the property node is set to write instead of read. Right click the property node to change it.
(2,731 Views)
Paul;
I've attached a simple example VI performing what you need.
I hope that helps.
Regards.
Filipe Altoe
Application Engineer
(2,731 Views)
