10-06-2023 11:09 PM
As you can see below, the letters are touching the top line of the box. Also GRCK and 5000 are touching each other. I tried changing the size, but the issue still remains. How do you solve this issue? Making texts fit in the box perfectly.
10-07-2023 01:20 AM
The two checkboxes below the text color will help with that. There are also some arcane ways to control the placement by using horizontal lines, but I can't remember what they are.
10-07-2023 09:21 AM
Which version of LabVIEW are you using?
Have you tried "Small Fonts" ?
10-07-2023 09:25 AM - edited 10-07-2023 09:29 AM
Are you a real person? Are you trying to "reverse-engineer" LabVIEW? Why are you doing weird things with the LabVIEW Icon Editor? What made you choose a "Font Alias" (which you can see doesn't pay attention to the Font Size entry, 0 in your example)? What you are showing is not a "subVI frame", it is an outline for a VI Icon (since you are using the Icon Editor).
The "answer" to your question is to substitute "Small fonts" for the Font, "center" for alighment, and 9 or 10 (point) for the size. Learn about the Icon Editor. Learn LabVIEW.
10-07-2023 10:43 AM - edited 10-07-2023 11:01 AM
On a side note, you don't even need to use the "icon text" tab. You can add free text anywhere on the "layers" tab.
(no limit to four lines and specific placement. You can set the font in the menu.)
Also note that your text is tinted and blurred because of cleartype interference *See below).
Nice text is not trivial with the limited number of pixels available. I've been know to write certain text pixel-by-pixel instead of using any text tools 😄 )
*Almost everything is using clearytpe. If you take a screenshot of the icon editor and zoom in 600%, you can see that none of the text is true B&W, but tuned to the arrangement of the RGB pixels of your LCD monitor.
