How do I know if an input is wired from a calling VI?
I need to make a decision based on whether the calling VI has wired to the input of the sub vi. Is there a property node reference to do this?
(2,966 Views)
You could make the default value of the control in the subVI something unusual (NaN, -Inf, -1), i.e. select a value that does not occur as input in normal use.
In the subVI, simply check if the value is "unusual". If true, the connector was not wired. 😉
Message Edited by altenbach on 03-30-2005 03:15 PM
(2,964 Views)
I understand. But what if the control is boolean. True and False are my only options.
(2,955 Views)
Well, I could not find an obvious solution, which does not mean it is not there. 😉
Basically, you want a 3-state input from a single boolean (true, false, unwired). I personally would not overload a boolean like that. If you want three real states, use e.g. a ring, enum, [-1,0,1], or similar.
If "unwired" would just trigger some error condition, you might want to solve the problem by defining the input as required, forcing you to always connect it.
(2,946 Views)
Hi
In LV 7.0 exists a property ConPane, which is just writable (see attachment). I don't know if there is any change to this property in LV 7.1.
Anyway - I just can agree with the mighty wizard ;).
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
(2,941 Views)
