How do I get the version of labview a VI was saved in at runtime?
I want to get the version of labview that a VI was saved in so i can display it on the front panel.
Message 1 of 8
(3,141 Views)
If you want the LabVIEW version, you use a property node. Right click and Select Class>VI Server>Application and then select Properties>Application>Version Number. This will return a string. If you want the revision number of a VI, its Select Class>VI Server>VI and then select Properties>History>Revision Number.
Message 2 of 8
(3,138 Views)
Dennis,
Just short note. Revision Number of VI is available in Development Mode only. It is not available in Run-Time Engine (in builded application will be always returned zero).
with best regards...
Message 3 of 8
(3,138 Views)
Although LabVIEW seems to know what version it was previously in, (it shows this information when you close a VI without saving and it promts you to save, you can click 'Explain' and it says it was in a previous version and what that version was) I don't think you can get that version number through a property node or any other means. This is probably due to the fact that as soon as you open a VI that was saved in a previous version, it recompiles it to the current version.
Ed Dickens - Certified LabVIEW Architect - DISTek Integration, Inc. - NI Certified Alliance Partner
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 4 of 8
(3,138 Views)
Andrey Dmitriev wrote:
> Dennis,
That is not completely true. The Revision number and History are part of
the Front Panel resource and as such get removed when the Front Panel of
a VI is removed during building of the application. If the Front Panel
is maintained the revision history should stay present.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
Message 5 of 8
(3,138 Views)
Hallo, Rolf,
Can you post here example of builded executable with illustration how it is possible to obtain Revision number? I agree, that Revision number is a part of front panel and saved in executable, when front panel is present (i checked this, its true). But this property node just not available in Run-Time (this also described in help). Its impossible to obtain revision number programmatically in builded application.
with best regards,
Message 6 of 8
(3,138 Views)
How about using *.ini file which can store the reversion number at development environment, then you can read it at run-time environment.
of course you should add the ini file into support dir.
http://www.vitst.com
Virry Test & Control
LabVIEW Certified Developer
Message 7 of 8
(2,874 Views)
Dennis' answer is probably the best, since at run-time the VI would have to at least been compiled before you can run it and whether you're running it in LV or in a built application, you know the version in advance.
You can get the version of LabVIEW in which a VI file was saved by calling the Application class method Get VI Version.
___________________
Try to take over the world!
Message 8 of 8
(2,854 Views)
