I have been creating random numbers that I'm using within a system, the system is working fine, but now I have realised that the random numbers must be outputted to speakers in such a way as to filter out all but a low frequency range.
I was thinking about generating a dither signal with a bandpass filter, but could not get it to give me out a full array of 250 values which I could then manipulate.
The sampling frequency of the output is 200Hz and the 250 data points must fall within the 0-100Hz range.
Another course of action I am considering is to use an FFT and an inverse FFT to get the data that I'm looking for, but I'm fair
ly inexperienced with using labVIEW and can't quite get it to work.
Thanks for the help,
Hank.
