How do I fit a curve with two independant variables
    I should have to fit a model just like the one you mentioned (Z=AX+Bx**2+CY+Dy**2+EXY+F), but my data are not sorted. Unfortunatly I don't know LAbView very much, so I don't understand how I can use your Vi with them... after I add new connections, which kind of modification do I need to do??Robot Sad
Thanks a lot
       Alessandro
Message 11 of 12
(1,241 Views)
(Since this is a new problem, you should have started a new thread.)
Anyway, your equation is linear in all coefficients, so you can just use the "general LS fit". have a look at my example here:
http://forums.ni.com/ni/board/message?board.id=170&message.id=129944#M129944
(disregard the levenberg-marquardt implementation in the quoted example)
Message 12 of 12
(1,231 Views)
