How do I extract the x-values from a waveform cluster (x0, dx and Y)?
I have a waveform cluster (x0, dx and Y) and I want the x-values in a one-dimensional array. How do I do that?
Message Edited by arnold_w on 08-18-2008 06:14 AM
(3,691 Views)
Hi arnold_w,
you can use a for loop to get them. Connect the size of Y to the loop count and add inside the loop dx to the value before, start with x0 or whatever you need.
Hope it helps.
Mike
(3,684 Views)
Ok, thanks. I was hoping there would be a conversion function for this, but I guess there isn't.
(3,674 Views)
Hi arnold_w,
this is your conversion function. Smiley Wink
Hope it helps.
Mike
(3,659 Views)
There is a built-in function if you want an array of timestamps. It's called Get Waveform Time Array.
(3,652 Views)
Ok, thanks!
(3,636 Views)
there is a function: Convert Spectrum Cluster to XY Cluster
then you can unbundle to get the X component
(3,220 Views)
