How do I export a counter from a task with multiple counters
Hi All,
I have a quadrature output VI that works 100%, outputting the frequency on the default pins (I'm using a NI-6284, so the default CTR0 and CTR1 pins are PFI12 and PFI13). During my development, I made a silly mistake and routed the encoder pins to PFI 12 and PFI14.
What I need is to move the signal from the PFI13 to PFI 14, which is supposed to be simple.
I've tried a few ways of doing it, including DAQmx dis/connect terminals (very clunky),  and DAQmx Export Signal which gives me trouble because there are two counters in the task and the function can only export 1 counter.
Please take a look at the attached VI and let me know what solution I should implement.
Best,
Adrian
(3,449 Views)
Hi ARL00000000000…
I have been doing some research into this and came into the following Knowledge Base article that explains sevral methods to  Internally Route Counter Signals in LabVIEW. I believe that's basically what you are trying to do so hopefully you might find it useful!
Regards!
Sil.VI
(3,374 Views)
Hi S,
Thanks for the reply. I also came to that page, which is helpful.
What I've ended up doing is using the counter property node to specify the output pin of the counter that I need to move, and left the other counter at the default.
I'm not sure if this is the best or most elegant solution, but I haven't had any problems with it as yet.
I was hoping to hear from the community what the safest and most elegant solution would be, as the "Export Signal" VI looks like quite a nice option, but may well be overkill for my purposes.
Thanks!
(3,353 Views)
