How do I enter different sets of inputs over time?
I'm making a program where I need to change the voltage into two different motors throughout a set period of time:
ex
Start: 5v 1v
after 5 min:  1v 2v
after 10 min: .7v 2v
and I need to program it to work for several hours.
I already have most of the program built up but I can't figure out how to get my numbers from a spreadsheet(or document) into my program.
Thank you,
Lost Student
(3,081 Views)
To get your numbers from a .txt file you can use Read from Spreadsheet VI which produces an array. Make sure that you have checked marked "Read whole File" or something similar.  At each index of the array, a different line from your input file will be in it. You can just index it and convert to a number. There is your numerical input.
As for the program to  run for severel hours or each part running a 5 min interverls like your example looks like: create a vi that its only job is to loop.
Time you want a set point to run / setting for Time delay = # loop iterations
This will control how long the program runs
hope this helps.
(3,076 Views)
File I/O Palette  > Read from Spreadsheet.vi
EDIT:  Too late! Smiley Sad
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(3,075 Views)
Keep in mind that a spreadsheet does not mean an xls file. It is a text file with columns which are by default separated by a tab.
LabVIEW 2012
(3,071 Views)
Good point Steve.  I never use XLS, ActiveX or the Report Generator Toolkit so I often forget that when many people say "spreadsheet" they mean an Excel spreadsheet.
Since Excel has extra formatting embedded in it the simple LabVIEW primitives can't read it correctly.  My advice is always to save to a raw data format like Tab Seperated Values.
(3,052 Views)
I found the "Read From Spreadsheet"  but I coudn't find a "read whole file" button or conector.  I'm also not sure what you mean by "index and convert."
Thank you,
Falcon9a
(3,032 Views)
Accepted by topic author Falcon9a
I was actually able to get a friend to help me with this one, If you put a double into a "For" loop it cycles through all the numbers in order 🙂
(3,019 Views)
