How do I edit an xControl once it is placed in a vi?
I am hoping that this is a beginners question:
I am evaluating the use of xContols in an application I am developing.
As soon as I place an xControl on a Front Panel, It locks the xControl so that I can no longer edit any of the properties.
Is there a button/menu option I can select to enable me to develop it's functionality?
I get this panel when I as "Why is this library locked" - and this is just on the Dual thermometer example!
At this stage, to edit the funtionality I have to remove the control from my test app, modify the xcontrol and then put it back in. - Not Cool!
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
(1,616 Views)
Accepted by topic author Timmar
In the XControl (or Project) window, Right-Click the XControl and choose 'Unlock Library for Editing'.  Make your changes, then go back and Apply Changes to Instances.
(1,610 Views)
Not sure Why I missed that,
I also found that if I close the test panel that it unocksa as well.
(1,604 Views)
