How do I download Instrument I/O Assistent for Labview 8.0 ?
Could you please repost the file "instrument I/O assistent for Labview 8.0?
Huy
Message 61 of 68
(1,902 Views)
Hi Huy,
You can click here to download the Driver CD.  Once it downloads, you can run it and select the Instrument I/O Assistant from the installation option screen.  Unfortunately, there is currently no separate installation of the I/O Assistant.
Let me know if you have any questions or trouble.
Have a great day!
Chris R.
Message 62 of 68
(1,900 Views)
Chris,
Is it for Vista or XP and is it valid for LV 7.1 also ?
- Partha ( CLD until Oct 2027 🙂 )
Message 63 of 68
(1,892 Views)
Hi Partha,
That version of the driver CD is compatible with Windows 2000, XP, and Vista (This information can be found in the drvier CD readme.html file) and the driver versions included should work fine with LabVIEW 7.1.  If there happens to be any drivers on the CDs that will not install into the LabVIEW 7.1, you can download and install an older version separately, but again, you shouldn't have any problems since we always try to make the driver version backward compatible.
Best of luck and have a great day!
Chris R.
Message 64 of 68
(1,884 Views)
Chris,
Kindly see the post below to get rid of my problems. I installed Nov 2006 Device Driver CDs along with LV 7.1 [ after many uninstallations & reinstallations ], but still the problem persists...
Please read from the beginning & try to solve my issue.
http://forums.ni.com/ni/board/message?board.id=170&message.id=273943
Message 65 of 68
(1,880 Views)
Hi Partha,
It looks like Dennis helped with your other forum.  If you have any other questions about the Instrument I/O Assistant, feel free to post back in this forum.
Have a great day!
Chris R.
Message 66 of 68
(1,862 Views)
Dear Staff,
I am working on the project using NI DAQ model USB-6009. Please advise
me
what
driver should it be for this DAQ and also what the I/O Assistant
Interface
software should it be for this instrument as well. Where can I down
load?
Huy
NI Software :  LabVIEW  version 8.0
NI Hardware :  Multifunction DAQ device USB-6009 OEM
Driver Version :  NI-DAQmx 2.2
OS :  Windows XP
Customer Information :
huy le
sjsu
US
huydle2004@yahoo.com
Ph: (408) 2722698
Message 67 of 68
(1,825 Views)
Hi Huy,
You will need NI-DAQmx for your USB-6009 and for the I/O Assistant, you will need NI-VISA and the Driver CD to install the I/O Assitant from.  For additional details, see the posts above.
Best of luck getting everything set up and have a great day!
Chris R.
Message 68 of 68
(1,815 Views)
