How do I connect an XControl to my VI's connector pane?
Hi all,
LabVIEW lets me connect built-in controls to my connector pane, but won't let me connect an XControl. I'm puzzled -- isn't an XControl meant to behave like controls on steroids?
Is this possible to make that connection, without creating yet another type def?
Thanks!
Certified LabVIEW Developer
(3,015 Views)
Ah, of course... I can make a control directly out "MyXControl.xctl: Data.ctl"
It would still be nice to be able to connect the XControl directly
(3,014 Views)
That makes sense.  The point of an XControl is to handle GUI.  So putting an XControl in a subVI that will never be seen doesn't make any sense.
(2,991 Views)
I agreed with this at first, but then I thought of reasons you would use an XControl in a subVI.  I can make an XControl with custom methods that perform some functions that are complicated.  Say I have a XControl that is an array of doubles, I could have a invoke node method, that performs a rate of change calculation, given a dt as my input.  In this simplistic example I would much rather have a subVI that I pass my data into, but I could see someone putting a bunch of functions in an XControl and then use its methods.
Another reason why you may want an XControl in a subVI is maybe the subVI will be shown, but you want to pass in the value to that control to a startup value.  So when the UI is shown by calling the subVI, the user sees it it has the starting value that maybe different from the default value..
(2,977 Views)
Yes, Hooovahh pointed out some valid use cases.
Mine was this: My front panel has 4 instances of an XControl. The user can manipulate each independently, in any order. When the user clicks "continue", the data from all 4 XControls are to be passed into a subVI for a combined analysis.
My usual approach for creating subVIs that take custom datatypes is to right-click the output data wire, click "Create" -> "Control", then cut+paste the new object into a subVI. This works with "normal" controls (e.g. typedefs), but not with XControls.
(2,958 Views)
