How do I connect LabVIEW 8.2 to an Allen Bradley PLC?
How do I connect LabVIEW 8.2 to an Allen Bradley PLC?  I am looking for any documentation or help with this topic.
Sean
(4,482 Views)
Hi Sean,
There are a number of ways to connect to your PLC and it all depends on what interfaces your PLC supports.  Most customers using Allen-Bradley PLC's use RSLinx OEM to communicate with the PLC.  This program contains an OPC server and you can retrieve the data from the OPC server using either LabVIEW's datasocket VI's or the Datalogging and Supervisory Control (DSC) module for LabVIEW.
Connecting LabVIEW to an OPC Server through a DataSocket Connection
LabVIEW DSC Module
If you don't have the Allen-Bradley OPC server you can use our Industrial Automation OPC Server (IA OPC) providing your specific PLC is listed under the supported devices for this OPC server.
NI Industrial Automation OPC Servers
Devices Supported By the IA OPC Server
-Justin D
(4,453 Views)
SeanWat wrote:
.... I am looking for any documentation or help with this topic.
There's also Using RSLinx OPC Server which goes into a bit of detail regarding the AB end of things. It is ~5 years old and thus is a bit dated ... but it may help.
Fading out. " ... J. Arthur Rank on gong."
(4,445 Views)
You might be able to get a modbus card for allen bradley. Then use the NI modbus library. It also depends on how much data you need to read. 100's use serial port. 1000's use opc server and ethernet.
Message Edited by unclebump on 11-17-2006 10:26 AM
(4,431 Views)
Donald wrote -
Yes - unfortunately it is outdated. I've posted a spearate query requesting information on the settings for an ethernet connection - not many people will still be using the DF-1 port.
(4,329 Views)
