10-09-2013 01:03 PM
I am trying to build an executable using Application Builder so that I can see the vi on the web. I have used the web publishing tool and had success on the computer running Labview. When I go into options and check Enable Remote Panel Server as suggested in many FAQs and I build the installer, the VI works fine but is not visible on any browser. I have looked at various FAQs and it seems as if i'm missing some small component to get this working. If I type localhost:8080/[name_of_vi.vi] I was expecting to get some type of response.
Solved! Go to Solution.
10-10-2013 07:48 AM
Hi todd1313
Did you read the following tutorial?
http://digital.ni.com/public.nsf/allkb/7F95D43D3F50FCAC8625710E000068E1?OpenDocument
You can start a new project and follow all steps to understand how it works, and then adapt it for you own project.
Give me feedbacks to know if you succeeded.
Have a nice day
10-10-2013 10:58 AM
Hi Jean,
That's exactly the solution that I was looking for. I searched through many similar situations but never came across one that was tailored to my problem.
Thanks again for your help!
Todd
