02-21-2006 02:42 PM
02-21-2006 03:01 PM - edited 02-21-2006 03:01 PM
Message Edited by jasonhill on 02-21-2006 03:01 PM
02-22-2006 11:09 AM
02-22-2006 11:24 AM
02-27-2006 07:26 AM
02-27-2006 07:39 AM
Aldenbach is right about the rgb systems, if you are looking for equality you could use the equals to compare the array and index the pixel for the boolean value. I have played around with something like this called a confidence map where successive frames of a moving video were compared for each pixel I took the RGB distance between SQRT((Red1-Red2^2 + (Blue1-Blue2)^2 + (Green1-Green2)^2) and did a moving average of a few frames to create a new image, the neat thing about this is that stationary objects go to a zero distance while moving objects (changing or non equal pixels) have a larger value (especially near edges of objects) and the recreated image just contains "objects or interest". Just a few comments from my experiences on the topic.
Paul
02-28-2006 09:14 AM
02-28-2006 12:03 PM
Good catch on the jpeg compression lossy problem. I didnt even think of that when I was doing my image analysis it wis a RGB bitmap format very time consuming but it was for off line analysis. Headers should also be checked to verify that the data is in the same format (color depth ...)
Paul
