How do I click on a cell in a table control, and display the value in a string?
What I would like to do is to click on a cell in a table control, and have the value of the cell be displayed in a string indicator. What ever cell I click on, I would like the value to be displayed in the indicator.
Thank you!
(3,057 Views)
Accepted by SciManStev
Use the property "Edit Position".
(3,051 Views)
... or
Event >>> ouse down for table.
Use Coords" to feed invoke node "point To Row Column" and returned "Cell Postion" can be unbundled to produce the row and column tht can be used to index out the value.
Ben
(3,047 Views)
Thank you! I had tried everything but that. I knew it had to be easy.
(3,046 Views)
Also thanks, sorted my Table issues too. cheers
(3,000 Views)
