How do I access the channels of a 40 channel single-ended multiplexer 34908A module that inserts into the 34970A Data Aquisition Unit throught the LabVIEW software.
Thanks Mac. You are right about the methodology using switch.vi and 299 closing the bank switch whe the second slot is being used.
It's just that I could not physically locate the bank switch in the off chance that I wanted to manually close it...do you see it on the module? I can't find it.
Thanks!
Message 21 of 21
(461 Views)
