‎04-26-2007 02:40 PM
‎04-26-2007 03:12 PM
What exactly do you need help with? How to replace the Read of the internal DMM or how to do a scan if the external DMM cannot store a series of readings? In the advanced scan example, there is a HP34970A Read function. If you are not using the internal DMM, you would have to replace this with whatever code is necessary to read a different instrument's buffer. The other way might be to not program the 34970 for an automatic scan at all. In a loop, you would set a channel to close, read the external dmm, increment the channel number, and repeat.
If you need more information, please provide the details on exactly what you are trying to do and with what external instrument.
‎04-27-2007 03:57 PM
‎04-27-2007 04:41 PM
‎05-15-2007 10:58 AM
‎05-16-2007 12:09 PM
‎02-11-2008 02:20 PM
‎02-11-2008 02:31 PM
I also cannot tell where the bank switch is located on the module. I see a picture in the manual but am unable to find it on the actual module (yea I feel very bright 😞 )
Can you please point me in the right direction...thanks!
‎02-11-2008 04:26 PM
‎02-13-2008 01:34 PM
