How do I Control the Windows "Close" Button (Little Red "X")
Hi All,
Is there a way I can configure my VI to shut down in a controlled manner if the user clicks the little red "X" at the very top right of the LabVIEW program window (see attached jpg).
I would like to set my program up to shut down the com port and exit normally if someone clicks that button.
Any help would be greatly appreciated.
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2023 (Yeah, I'm that old...)
(13,928 Views)
Use the event structure and the panel close event. In this event you can terminate the vi in a proper manner before the window is closed.
Ben64
(13,921 Views)
Use an event structure with an event configure to catch the...
<This VI>   Panel Close
event.
Ben
(13,919 Views)
Remember to wire a True to the discard event node, otherwise the VI will close anyway before you've had an chance to let any of your shutdown code do its work.
(13,910 Views)
More specifically, you should use the "panel close?" filtering event (note the question mark).
With this you can discard the event and do whatever is more appropriate for the shutdown instead.
(13,889 Views)
Be aware that the Panel Close? event will capture the littel red X, but it will not capture the File - Exit or Ctrl-Q event.  To capture this, you need another event case for Application Instance Close? event.  Similary, you can wire a True to the Discard terminal to stop the closing.
- tbob
Inventor of the WORM Global
(13,882 Views)
Thanks very much, all.  I will work on implimenting the event control ASAP.
Forbes Black
(13,847 Views)
