03-10-2016 12:03 PM
I'm using LabView 8.5 and I have a Waveform Graph with multiple cursors.
I would like to programatically read the Cursor.Position Property Node from the cursors.
However, the property node I create from the graph terminal only reports on the first cursor, regardless of what cursor is selected. There does not seem to be an input to specify which cursor.
Any suggestions?
Thank you,
Frenk
03-10-2016 12:15 PM
Frenk,
I am not sure how much things may have changed since LV 8.5. I think you need to read or set the Active Cursor property before you work with the Cursor. Position property. If you expand the property nod to include both properties, be aware that property nodes execute in top down order. So have the Active Cursor property above the Cursor.Position property.
Lynn
03-10-2016 02:03 PM
Thank you!
I hadn't realized the ActCrsr property was there (it is not quite in the same place as the other properties for LV8.5).
Great, it works! Thank you!
Frenk
