05-24-2016 08:44 AM
The newly released laptop computers (with enhanced configurations) do not have PCMCIA slot. How is it possible to use them with the PCMCIA-CAN interface?
05-24-2016 08:52 AM
Did you used a search engine to look for a USB<->PCMCIA interface device?
However, even if there exists one (which i doubt) i definitely do NOT recommend you to use such a thing. It is by far easier and in long term most likely cheaper to update hardware and software to use a fully supported hardware which also provides some warranty.
Norbert
05-24-2016 02:58 PM
@mjesfand wrote:The newly released laptop computers (with enhanced configurations) do not have PCMCIA slot. How is it possible to use them with the PCMCIA-CAN interface?
You can't.
I have two laptops with the newer ExpressCard slots and I bought an ExpressCard to PCMCIA/PC Card converter, and it would not work on any of the PC Cards I had.
You shouldn't have to re-write much if any code if you upgrade to a USB-CAN interface.
05-25-2016 02:14 AM - edited 05-25-2016 02:16 AM
You can't.
Fully second that. The PCMCIA standard was based largely on the old ISA architecture while the ExpressCard standard is largely based on the PCI standard. They never worked very well together and any bus bridge device was usually only working well for software drivers that were actually specifically written to work with those bridges. The dream to make a fully transparent bridge between those standards never really materialized anywhere. Even modern PCI to PCI bridges suffer similar trouble that small little bugs in the bridge hardware or the software drivers make it malfunction.
In addition most computers nowadays do not even have ExpressCard slots anymore so even if the PCMCIA to ExpressCard converter would work, which it generally doesn't for anything but the most trivial devices, it would be a temporary bandaid again.
