09-09-2014 09:28 AM
Hey guys,i need some help.
I have 113 inputs and want to put a numeric counter to choose which input i want to see on graph.
Can i do it?!
Thank you all!!
09-09-2014 09:33 AM - edited 09-09-2014 09:34 AM
09-09-2014 12:31 PM
Hi GerdW!!
Thanks for you attention!!
Im begginer in LabVIEW yet and i can't solve my problem.
I pick one part of my program and attached here.
Can you explain me how can i put an indexArray into my ReplaceArray?
My front paniel is attached here too.
**Is this the best graph for this situation?
Thank you again!
09-09-2014 01:33 PM - edited 09-09-2014 01:34 PM
You have an array with the 7 different channels appended at 16 points each. Simply get the array subset based on the desired trace. Here's a simplified example.
You can make the control a ring with the items named accirding to the channel names.
09-10-2014 09:20 AM
altenbach escreveu:
Hi altenbach, thanks for the answer.
I tried this way and it doesn't work.
Now i have 16 points of temperature in one graph.
I want 1 point of temperatue on graph.
Example: I select point 7 and show me on graph just this point.
Is this possible?
Sorry, im begginer!
09-10-2014 10:36 AM
If you want to show one point on a graph, you need to make sure that you use a plot style with point symbols. If you use a line graph, plots won't sow if there is only a single point. Lines need at least two points.
Please attach your latest version for more detailed help.
09-10-2014 12:04 PM
altenbach escreveu:
The way you spoke really worked, but the chart is showing 16 inputs for each channel.
What I would like is to show one ipunt only, so I could view it on the chart.
I'm working with thermocouples, then it would be great if I could view these 113 entries separately in the chart.
Example: I want to see Input 65, so i change my numeric counter to 65, then i can see input 65 in the chart.
09-10-2014 12:15 PM
09-10-2014 12:22 PM
altenbach escreveu:
(Posting by phone, cannot look at code).
A chart is very different compared to a graph. What do you actually use?
Graph.
I want one graph that i can choose which input i want to see.
So i will see one Graph with Temperature(one input) X Time .
09-10-2014 12:30 PM - edited 09-10-2014 12:48 PM
Please attach your latest code. Your terminology is not precise enough (chart vs. graph, counter vs. control, etc)
