07-03-2019 01:18 AM
I have 2 y-axis and 1 x-asis.
can anyone help me develop the x-y graph please.
Thanks in advance
Screenshot attached
07-03-2019 01:23 AM - edited 07-03-2019 01:25 AM
Hi akshay,
a plot in a XYGraph can be supplied as cluster of [X array, Y array]. To have more than one plot you can create an array of those clusters - as is explained in the context help of the XYGraph!
Where are you stuck at creating the plots?
To get that 2nd Y axis you need to create the Y axis using the context menu of the graph (aka right-click menu), then create Y axis, then swap side of the Y axis…
07-03-2019 02:26 AM
I wanted to know how can i plot the second curve in the same graph after plotting the first curve
07-03-2019 05:40 AM
07-04-2019 02:15 AM
My X-Y graph takes the values from only one Y-axis.
Is there a way to select the particular Y-axis.
07-04-2019 02:22 AM
