How can i control the I2C bus with Labview
Hi
How can i control the k8000 from http://www.velleman.be ( I2C bus) with
Labview.
all info is welcome.
victor.wouters@advalvas.be
(3,719 Views)
if you are using Linux (and the Linux version of LabVIE W) it should be
fairly easy to use the lm_sensors ( http://www.netroedge.com/~lm78/ )
libraries and source code to control a device connected to a PC's I2C bus.
Go here http://www.netroedge.com/~lm78/hardhack.html to see how to tap into
the I2C bus of your PC. You may be able to apply info here to roll-your-own
on a MS Windows 98 / 2000 OS.
Chris
"Wouters V" wrote in message
news:39fff2de$0$4493$73bec57d@news.be.uu.net...
> Hi
with
> Labview.
(3,719 Views)
This is something we supply that will work through a parallel port. It comes with vi's
http://www.calbay.com/I2C_driver.htm
Buck
(415) 258-9400
(3,719 Views)
I may be late with my answer but check out this product for controlling the I2C bus. It is one of the most economical and flexible products for this application that I found.
iPort/AI by Micro Computer Control at www.mcc-us.com
Good luck!
(3,719 Views)
hello maibe I'm late but I found this, you got all information you need 🙂
http://home.12move.nl/jh1996/
Regards Yves Prignon
(3,719 Views)
