How can i access the Mightex USB camera from MAX 2009
Hi All,
     Im using Mightex USB camera for my application and im using LV2009 and Vision Assistant 2009. In MAX i can found the Mightex USB camera,
whenever i want to grab from USB camera through MAX or LV it is capturing the images but if we stop capturing try to do some other thing in MAX means the total MAX will get closed with some unknown error. In labview also while running the USB close function the total labview application Get closed? any body knows about this problem. what should i do for overcome this issue.
Kalanga
(2,584 Views)
I have used an USB camera before, you have to install the IMAQdx drivers which you can find in the device drivers CD under vision acquisition.
I hope this helps.
Regards
CLD
(2,572 Views)
