How can I use mutually exclusive numbers to control 4 logic values?
Hi, this is my first post on the forums, so forgive me if there's anything I miss
I'm trying to use LabVIEW to control a 16 channel external mux using 4 digital logic outputs.
Therefore I must somehow convert a user selectable integer to 4 separate boolean outputs as per the following table (ignore the "otuput" column)
http://www.kollewin.com/EX/09-15-17/truth_table.jpg
This should hopefully be easy for the seasoned programmers between you - alas any help would be extremely appreciated.  Thank you.
(2,229 Views)
It sounds like you  have a number and you would like to convert it to a Boolean Array.  Perhaps in the Boolean pallete there is a function that converts a "Number to Boolean Array".
If you want separate booleans, use Index Array (pull down the bottom to give the first 4 elements, no need to explicitly wire the indices since it will default to 0-3).  If you would like an Array (I would) use Array Subset to return the first four values.
Hopefully enough information.
(2,218 Views)
