How can I use 3 buttons to control the transitions of my case structure?
Build the three booleans into an array and search for the element that is true. Wire the output to a case structure, for example. I am assuming that the code prevents more than one to be true at once. What should happen if none are true? What is the mechanical action of the booleans? What is the design pattern of your code?
Message 11 of 14
(1,088 Views)
I just want to use the three buttons as part of the front panel. At one time, only one button can be true. I am receiving data by three channels through the port and wants to perform this task by having three buttons. These all things will be a part of subvi.
Message 12 of 14
(1,074 Views)
If only one button can be true at any given time, I would use a radiobutton control instead of three individual booleans.
Is one button always true or can also no botton be true?
There are all very basic things. What part is giving you problems? Can you attach a simplified version of the code you have so far?
What are "these things". Are the buttons on the front panel of an interactive subVI or on the main VI?
Message 13 of 14
(1,041 Views)
Depending on your exact needs, you may be able to get away with using a simple control and Index Array to select the array of choice from your 2D array...? Just select the array you what?
Message 14 of 14
(1,004 Views)
