How can I transfer .txt-file from LabVIEW to DIAdem SCRIPT?
hi,
I´m using Labview to collect measures and transfer them to Diadem.
but how can I transfer .txt-file from LabVIEW  to DIAdem SCRIPT?
thanks for your help!
(2,328 Views)
Smiley Indifferent
(2,314 Views)
I don't have DIADem at my current laptop.
But what is that you want?
Do you want to run some special txt file as a script command set? There should be a VI to run script commands from LabVIEW in DIADem script, just open the text file and read it's contents.
In the same way you could create a script line that sets some variable that contains your filename.
I'm not too experienced on script so maybe you can better post a such a question on the DIADem forum
Ton
My LabVIEW Ideas
(2,309 Views)
 Have you tried the Diadem Forum?
(2,308 Views)
THX!!!Smiley Wink
(2,282 Views)
For anyone who still needs a way to read TXT files in DIAdem, I have created a Community Example Program for this:
Reading and Writing TXT to Report with DIAdem Script - Discussion Forums - National Instruments
https://forums.ni.com/t5/Example-Program-Drafts/Reading-and-Writing-TXT-to-Report-with-DIAdem-Script...
Eric H.
Applications Engineering
(1,739 Views)
