02-28-2006 05:54 PM
02-28-2006 06:02 PM
It all depends on what you need to check.
PPS contains only timing info, IRIG contains time and timing.
I will assume that this is standard IRIG B, which means that the timing accuracy is derived from the zero crossing of the analog signal, or the rising edge of the digital. You will need some kind of high speed data acquitision and trigger.
Keep in mind that EVERY zero-crossing is on-time, they are just not at the PPS. That is your zero crossings occur on-time every 1 ms.
02-28-2006 06:20 PM
02-28-2006 07:14 PM
I am just getting started with LabView and related stuff, but I am sure that NI offers Hi-speed DAQ cards.
You will need at least three channels: GPS-ref PPS, GPS-ref IRIG, GPS-test PPS.
Sample the GPS ref PPS until you get a rising edge.
Once you have the first one, configure the system to fire in 998 ms (or so) and acquire data on all three channels for 3 ms (or so)
You can analyze your arrays and determine your accuracy.
Fire again.
Lather rinse repeat
