How can I take a take an average of my voltmeter every 10 readings?
Here are a few recommendations:
1. Convert to standard DAQmx functions. It's not difficult and you don't have that dynamic data wire to contend with.
2. Read 10 data points at a time from your DAQ. This eliminates the need to have a loop to collect your 10 data points.
3. If you insist on using the DAQ Assistant as you currently are just put it in an autoindexing for loop - no need for a shift register.
4. If you need help debugging your code it is helpful to post your code - not just a picture. We can't see the settings of that DAQ Assistant, for instance.
Message 11 of 14
(583 Views)
I will try this tomorrow and get back to you all. Thank you.
Message 12 of 14
(575 Views)
I could not find any daqmx functions in the palette. They must not be included in the community version.
Message 13 of 14
(524 Views)
DAQmx drivers are a separate install.
Run NI Package Manager to install them after you are done installing LabVIEW.
Message 14 of 14
(519 Views)
