How can I store the sum from a numeric function for use after it has changed?
(2,804 Views)
Please be more descriptive over what you're trying to do. Body of message. Large area. Let the muse in you out.
I honestly don't understand what you're asking. If I had to guess it sounds like you want is a shift register, but I can't be sure since I don't know what you're doing.
Message Edited by smercurio_fc on 04-15-2010 10:49 PM
(2,787 Views)
Accepted by topic author pete_gibb
To be clearer, I am trying to write a program which monitors 4 current lines and then switches 1 off when the sum off all 4 exceeds a limit.
The problem I'm having is when my limit is reached, one of the lines is switched off as intended but this causes the total to drop below the limit which in turn causes the cut off line to switch back on, then off, and then continue to toggle.
Any help appreciated.
(2,776 Views)
hi pete_gibb,
 is your question answered ?Whatever the thing you" marked as answer" is not answer.Please change it.Coming to your query..to store the sum from a numeric function ,please try touse shift registers.
T hanks and regards,
srikrishnaNF
Srikrishna
(2,763 Views)
