How can I stop (freezing) the scope screen Tek MDO 4054C using labview
@ZhouRay200 wrote:
Thanks for your advice, the problem is solved, but not by using a trigger which can't wake up the scope.
Good to hear, but please do tell us what you found just in case someone has the same problem later.
 wrote:
Problem is solved. The flat sequence structure just for making each part looks clean when I try to design a new code.
 Superfluous.
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 11 of 13
(146 Views)
I used a super inconvenient way to run the scope again which is reset everything again with the auto set VI. All other ways I tried only to wake up the scope to the single mode.
Message 12 of 13
(141 Views)
Actually, I like that idea - makes it ready for the next person to use.  This should not be used to reset the o-scope between measurements, though, but only after you are done with the scope.
Bill
CLD
(Mid-Level minion.)
Message 13 of 13
(136 Views)
