How can I stop DAQ event?
hello
i use NI USB-6009 DAQ to read multi chanels in N SAMPLES mode, how can I stop the DAQ event if I want (before it ended)
i add my vi
thx
yechiel
(2,626 Views)
yechielo,
Even though the DAQ Assistant is a great tool for getting started with our DAQ products, you will sacrifice some control including the ability to stop a task before it is completed.
To get around this you will need to use our lower level VI’s.
And to stop the task during run time you can use the stop.vi
Also if you are new to DAQ then check out our Learn 10 Functions in DAQ and the DAQ tutorial.
Message Edited by Ryan N. on 03-12-2008 06:55 PM
Ryan N
Application Engineer
ni.com/support
(2,605 Views)
