07-03-2019 08:58 AM
I have the same problem, you can't execute the two input in the same time because you have may be DAQmx 6001 or 2..3.
You can choose whic I/O goes with number of channel, but you can't run them simultaniously..
I'm looking for a solution.
S.C
07-03-2019 02:16 PM
The User's Manual (http://www.ni.com/pdf/manuals/373060g.pdf) indicates the analog outs are dual independent DACs and have an audio-output mode. Is there an audio output option?
07-03-2019 04:13 PM - edited 07-03-2019 04:15 PM
I've solved the problem! Thank you!
I even have two channel selectors now! The problem was, that I did not create two channels in my synth_config.vi. I put my small Fgen test project in the attachments.
If you have anymore tips to improve this little problem, I'd be happy to hear them. (besides removing the local variables and rather directly connecting them)
07-04-2019 07:29 AM
Ah so you don't use the DAQ assistant but you use the Daq fonctions and Another VI to do it ? because 'im using two daq so I have to learn how to make a complex programm like yours..
07-04-2019 11:56 AM - edited 07-04-2019 11:56 AM
Yes, basically what I did there was creating a DAQ Assistant which had two output's active and with right mouse click on it and clicking "create code" you will automatically gain the .vi and the rest of the code. You can easily change certain parameters that way.
