How can I set widnows environment variables on launch of LabVIEW
I know that there are solutions ofr achieveing this with executables, and I can do it VI by VI, but I want to do this once, I want them to become part of my development environment, but not all environments, and I wondered if there were a better way than my current plan of creating my own exe to launch labview.
(2,611 Views)
How about creating a batch file to startup your LabVIEW system which first sets the environment variable and then launches LabVIEW? Executables launched from a batch file should inherit the entire environment of whoever started them up.
Something along the lines of:
SET MYENV="your value"
START "C:\Program Files (x86)\National Instruments\LabVIEW 2014\LabVIEW.exe"
Batch/shell script files may seem so last century, but they are still a viable and very powerfull means in all current operating systems.
Rolf Kalbermatter
My Blog
(2,602 Views)
They do indeed, which is what I'm using on my own machine, but for distribution to our production environment (which all uses labview development environments - scientific research needing quick responses that don't take time to build and deploy sometimes - and this was the design decision my colleagues made) that won't work as an option, unless I turn the batch into an exe, and replace the associated program for VIs to use that exe and alter all links to use it - which is a big job on 40+ machines, but a script to alter on startup would be far quicker. We may just end up permanently setting the environment variables, but I thought I'd ask for any other ideas.
(2,594 Views)
Not sure if this helps but I wrote a utility a while ago for reading/writing environment variables.  It doesn't do anything special just reg edit stuff and command line.
http://lavag.org/files/file/7-windows-environment-variable-reader-writer/
(2,564 Views)
