06-11-2009 03:55 PM
I have a Pulnix camera (model TM-6740CL) connected to a PC via an IMAQ interface. I use LabVIEW 8.2.1 and have been trying to create a small program for the adjustment of different camera parameters (shutter speed (manual), gain (ch. A/B) etc.) on-the-fly.
My question is: how can I use the "IMAQ Set Camera Attribute.vi" to control these parameters while grabbing? In particular, my problem is that I am not able to find the proper designations of the different attributes (such that they are processable by the imaq.dll library).
Maybe someone can give me a useful hint.
Cheers,
Benjamin
06-15-2009 04:52 AM
OK, I am now able to be more specific here.
I am using a NI PCI 1428 interface with the mentioned camera. The actual problem I have is that the corresponding icd-file available does not support all attributes that I would like to modify within LabVIEW. In particular, it does not contain any reference to Gain values or Reference Voltage.
My question now is: how can I address and adjust these parameters if they do not appear in the camera file? Has anybody come across an updated version which does contain these attributes? Or this there another way for me to attack the problem?
Any help will be much appreciated!
Benjamin
01-26-2012 10:53 AM
Please someone with ideas!! I have the same problem...
01-27-2012 02:16 AM
Attached you will find a camera file for the TM-6740 which includes some attributes, e.g. BitDepth, Shutter, ScanMode and so on.
If you are still missing some attributes you can add them by yourself using the NI Camera File Generator or contact Pulnix to add the attributes for you.
Christian
01-27-2012 06:02 AM
I totally agree with Christian. In the end I used the Camera File Generator to add some necessary features. I attach the file that is currently in use for our camera, in case it might be of interest.
Best,
Benjamin
01-27-2012 06:08 AM
Thanks Christian and Benjamin, I will se both files and will post...
