How can I set default values for Allocate Mode in AO config?
Hi, How can I set default values for allocate mode in AO config. To be specific, in the attached vi, I need to set the Allocate Mode in AO Config to 'Use FIFO Memory (6)' if the value inside my case structure is false and to 'no change (0)' if the value inside the case strusture is true.
(2,103 Views)
Accepted by topic author Varun Kumar
Create two constants for the Allocate Mode input (right click > create > constant). Place one in the true case of the case structure, and place the other one in the false case. Wire them to the same tunnel (border of the case structure), then wire the tunnel to the Allocate Mode terminal of the AO Config. I don't have Traditional DAQ installed, but that should do it.
Misha
(2,097 Views)
Thank You Misha, it worked Smiley Happy
(2,091 Views)
