How can I save my data from my DAQmx to a file with date and time?
Hello everyone,
I have developed my VI in LabVIEW 8.6 to make temperature acquisition using my daq board USB-6221. Well, the VI is running alright but when I press the button to save a txt file it's launches a dialog box to choose the path to save the file, depending the time you have delayed to choose a path to create it the first data are saved with wrong date and time. I believe the temperature data are correct (I guess these data were storaged in the daq buffer and after I have clicked OK to save the file it is appended to this file), but the date and time doesn't change in this period. Look the example below.
I have looked some examples in here, but some VIs do the same thing. Is this a DAQ board configuration error?
Thank you.
Diego
(5,230 Views)
Accepted by topic author DiegoSV
Alright, I found one solution putting up a timer inside the loop. This timer avoid saving wrong data, but the first value after I've already pushed the save button is saved on txt file.
Thanks.
Diego
(5,145 Views)
Hi
You can use TDMS file format to save the data. I have attached a reference Vi.
On button click you can log the data or remove the case structure and continuous log the complete acquisition data.
Thanks and Regards
Himanshu Goyal
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(5,135 Views)
Hi Himanshu,
Could post your VI in the latest version (8.6)? Thank you.
Regards.
(5,110 Views)
Hi
Please find the attached older version VI.
Thanks and Regards
(5,096 Views)
Thanks Hinamanshu. I´ve ran the VI here and have worked fine.
Sorry about the late response!
(5,071 Views)
