Hi Elvis,
Are you referring to executing a stored procedure in Access from LabVIEW? If so, we have examples that do this. Here's a
Link. If you're looking at calling something else, or if the above solution doesn't work, another (more tedious) solution would be to create a macro in Access to call that procedure. Then, in LabVIEW, you can call that macro using ActiveX and the RunMacro procedure. For more information on ActiveX methods in Access, I would refer to the msdn website. Hope this helps!
Jeremy L.
Jeremy L.
