How can I programatically change the Plot Style of a 3D surface?
I believe this can be done using a property node...however I am unable to find the property. At one point in my program, the plot style automatically switches to Points, and I want it to be Surface again later. I have a 3D surface reference wired to a property node, giving me the CWGraph3D properties. If the properties followed the menu style you get from right clicking on the 3d surface, I should be able to then select the property plots, and change the plot style. However, even though I can get a reference to the plot, the only property I can access is the count. I would appreciate it if someone could show me where I am going wrong, since Im confident this can be changed programatically.
Thank you!
Jeff
Using Labview 7 Express
(3,141 Views)
Hi Jeff,
here's what I did (found somewhere in the examples that come with LabView):
Message Edited by GerdW on 03-14-2007 04:28 PM
(3,136 Views)
Thank you that is exactly what I was looking for I just couldnt find it. haha as I copied the series of property nodes and invoke nodes, I realized that I had exactly the same thing already written to change the colourmap values...so the property wasn't as hidden as I thought!
Thank you
Jeff
(3,127 Views)
