07-20-2016 09:53 AM
Hello all
I am using a Modbus library built using classes. I need to view the data inside a VI which is part of a class in an inheritance tree. I cannot place a breakpoint in this class, or probe any wires or retain wire values. I have looked into creating a custom probe, but the option is not available. I have read through several documents on LabVIEW classes and tried the inbuilt help too, but I am sure I am missing something obvious. Please could someone point me to the right resource to use or tell me what I'm doing wrong.
Ray
Solved! Go to Solution.
07-20-2016 10:39 AM
@Tarsel wrote:Hello all
[...] I have looked into creating a custom probe, but the option is not available.[...]
Ray
Can you elaborate on this?
07-20-2016 10:48 AM
Why can't you place down a probe? Class controls/indicators don't show private data, but probes do (I believe they also show parent class data). If standard techniques don't work, why not create a "dump private data" accessor that reads off all private data? That can then be used in a normal indicator for debugging purposes.
07-21-2016 02:28 AM
Hi Gregory
If the program or running or not, I can normally right click a wire and the Probe option is available. In this case the option is greyed out or not visible (same for break points). I have read some of the literature about creating a custom probe and assigning it to the libray containing the classes, but the method outlined by NI requires me to be able to have the create probe option in the first place.
Hi ilovemath
I don't know why I can't place a probe, I think it will be something to do with whether I am looking at the class declaration or whether I somehow need to look at the instance of the class when the program is running. Not sure how to do this... I have tried placing an indicator and viewing it when running, but this doesn't seem to work either - no data is displayed. Again it looks like I am not looking at the right running instance. I could externalise the data by wiring to a terminal, but this then does not fit the class definition. The final option I can think of is to use a named queue, but it seems there must be a simpler solution.
Thanks for the replies,
Ray
07-21-2016 02:43 AM
@Tarsel wrote:
Hi Gregory
If the program or running or not, I can normally right click a wire and the Probe option is available. In this case the option is greyed out or not visible (same for break points). [...]
Ray
This indicates that the VI is configured for "Enable Debugging" = False (unchecked).
Norbert
07-21-2016 02:50 AM
Thanks Norbert - that looks like the problem. I can't test it out at the moment, but I now have the probe option - hooray!
08-20-2019 09:56 AM
I've tested it now. Its impossible to trace dynamic dispatch method. You can add wire probe inside DD method, but you'll not get any trace result. Am I wrong? (Debugging allowed.)
08-20-2019 10:39 AM
What are the reentrancy settings of the method? If it is a clone, you will need to add a breakpoint to the method to get your probe to actually probe the clone instance that is called.
08-20-2019 10:45 AM
