How can I plot over long time, from 1 to 24 hours, and width servral channels in one graph
I have try to get a plot over long time, 1 to 24 hours and more than 2 channels, up to 6 channels in same graph. What I have try is to use a xy plot and then by  letting the x axis min max be controlled, see picture, the thing is you can only use 2 channels to data on a xy plot, if I those a chart plot, when i use the same structure to control the max min for time span, no lines are plotted for some reason, see picture.
Regards // Thanks
Lars
WiFi Guru, proud holder of world record in WiFi, 421 Km @ 2 mbit/s
(3,080 Views)
You can put as many XY plots on one XY graph as you like, there should be an example for multi-plot XY (dont have LV infront on me right now).  you can build up in an array the X and Y values and periodically regraph them.  Change the X scal as you wish or just replot a subset of each XY plot.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,052 Views)
