12-04-2019 08:06 AM
Hello Everyone
It seems something very oblivious and easy but some how I am really stocked.
I want to plot a waveform, but instead y= f(time) I want to y= f(x) which x is a distance and y is Force.
I want to plot the force in function of the distance instead of time.
Thank you in advance.
12-04-2019 08:14 AM
Just edit the label for "Time" to be something else. It is just the default label because most of the time (no pun intended) time is the x-axis for people.
12-04-2019 08:15 AM
12-04-2019 08:29 AM
A Waveform Graph (as opposed to an XY Graph) is meant for plotting Waveforms, a LabVIEW data cluster construct that represents XY values assuming that the X Values are equally spaced and can be completely determined by knowing the initial X value (call it "x0") and the equal spacing (call it "dx"), while the Y values are represented by the array Y of all the values. Two common Waveforms are "sampled data" (where X is Time, and the Waveform Cluster labels are t0, dt, and Y) and "FFT results" (where the "sampled data" are amplitude, phase, or power, and the X corresponds to the initial frequency f0 and frequency interval df).
As other posters have noted, you are free to change the X and Y labels on the Waveform Graph or Chart to suit the units you are actually using -- just be sure that you are using Y values measured at equally-spaced X intervals, and that you identify the starting X ("x0") and the X spacing ("dx") in the Cluster.
12-04-2019 09:01 AM
Sorry I tried what you suggest and other staff too (see picture).
But Nothing works.
I want measured signal in function of Actual position.
The maximum value of actual position is 1250, but in the graph I see more than 3000.
12-04-2019 09:03 AM
This is a picture of the signals.
12-04-2019 09:10 AM
But Nothing works.
12-04-2019 09:11 AM
But Nothing works.
12-04-2019 09:13 AM
So in the picture I see 3 displays. Two are waveform graphs. The 3rd is an XY graph?
Is the XY graph correct? And if not, how is it wrong?
12-04-2019 01:34 PM
What is the logical connection between "actual position" and dt of the waveform?
If you really want help, attach the vi and some data. Truncated images are useless.
