How can I pass an array to another vi without using subVI
Hello all,
Is there a way to pass a 1D array from a VI to another without using subVI?
Message 1 of 11
(2,031 Views)
Yes.
Queues, Notifiers, Global Variables, TCP, UDP, ...
Jim
Message 2 of 11
(2,018 Views)
@Mmehrabin wrote:
Hello all,
This question, without code to clue us, makes no sense!  The simple answer is "Sure, just use a wire", but then where do you get "a VI" and "another VI" without having (sub)-VIs?  Maybe you mean something else by "sub-VI".  Maybe you mean "without using a wire".
Sorry, I don't understand the question.
Message 3 of 11
(2,012 Views)
I'm with Bob.  What?
My initial guess would VI Server?  Cuz in this scenario, you have potentially two "Main VIs" and no SubVI.  Still though, question needs to be worded better.  And code usually helps.
Message 4 of 11
(1,994 Views)
@Mmehrabin wrote:
Hello all,
Bob has a good point, your question is not a valid question, and I am guessing because you lack the knowledge to know what to ask.
Start here Introduction to LabVIEW and follow through the "12 step program" (LOL) first.
There are plenty of tutorialls and videos on teh NI site to help you learn teh basics
Unfortunately, most readers of this Forum, including some real Experts, have not mastered the skill of being able to read the code that Posters fail to post. If we cannot see "what you did wrong", we are unable to tell you how to fix it. (Bob Schor 28 August 2018)
Message 5 of 11
(1,989 Views)
Thank you for your fast answers. Let me explain more about the code. I have an FPGA code that sends some values by FIFO DMA. I receive them in a host VI and put them in an array. In this VI there is a while loop to receive all values from FPGA so I can not put it into another vi as a subVI. So I want to send the received array to the third host VI by value passing.
Message 6 of 11
(1,971 Views)
Adding to all previous comments, it's difficult to give you a solution.
- I am guessing you meant subvi means a vi which will reside in your vi. And to other vi meant both are running parallel?
- There are plenty of data communication methods in LabVIEW which includes all above answers.
-You can check and choose the data communication methods best suited for your application : http://zone.ni.com/reference/en-XX/help/371361L-01/lvconcepts/data_comm/
uday
Message 7 of 11
(1,970 Views)
This sounds like a prime example for a Producer/Consumer.
GCentral
Message 8 of 11
(1,954 Views)
I need to store some data from FPGA. Can I write them in a file on FPGA or I should transfer them to the Host VI then store them in a file?
Message 9 of 11
(1,922 Views)
Accepted by topic author Mmehrabin
The FPGA has no access to a disk.  You have to pass the data to the host (preferably with a DMA FIFO) and then the host can log the data to a file.
GCentral
Message 10 of 11
(1,919 Views)
